Briggs and strattion carb problem
John Cropper
05-30-2003 19:13:27
i have a tiller that has a 5hp engine that when u turned wide open it starts sounding like it choking out and u lose all the power please help!
Kent of SW MO
10-02-2003 14:10:56
 Re: briggs and strattion carb problem in reply to John Cropper , 05-30-2003 19:13:27
The throttle on some 5 hp briggs have the choke
at the "top" of the throttle. Back it off a little
is all you may have to do.
PAUL WALDRIP
09-12-2005 07:42:33
 Re: Re: briggs and strattion carb problem in reply to Kent of SW MO, 10-02-2003 14:10:56
SIR:I HAVE A 18HP BRIGGS STRATTION[4227-07] ENGINE THAT WANT IDLE DOWN..IT WILL RUN WIDE OPEN IF YOU LET GO THE GOV.... PAUL...
Adam P
06-03-2003 20:49:56
Are you sure it's a briggs??? I'm not sure about the specifics, but it might be designed that way. A lot of tecumseh engines are set up so that beyond full throttle is choke.
AP
Don't Turn It Wide Open!
05-31-2003 13:20:17
NM
