Stover CT 2 when made??
J I CASE
06-04-2003 19:55:06
I have a Stover CT 2 that I am restoring and would love to know when it was made.It is Serial # TB254011.
If you happen to know of a site that list engines and serial numbers for this or other engines I sure would appricate you letting me know/
Thanks J I
hobo jungle
06-08-2003 15:36:36
 Re: Stover CT 2 when made?? in reply to J I CASE, 06-04-2003 19:55:06
Here is a web site to go to to check out your serial number. I have a Stover also. From the number it would appear to be a 1936.
Link
Type it into the address bar just as you see it.
Hope this helps.
Hobo
Jim M (RI)
06-05-2003 08:18:07
J I, I have two Stover CT 2's but haven't had the time to start the restoration process. Harry's site (www.old-engine.com) has a wealth of information and I'm sure someone there could point you in the right direction. Let me know if you find out. I would also like to keep in touch via email as you go through the process. Hopefully we can help each other out. Jim
