Palmer Engine, PW-27?
SAm in NS
06-10-2003 03:29:54
I have been offered a small, old, marine engine. The gear box that is with it has Palmer cast into it. I found a few pictures of Palmer engines and it looks like a PW-27. It is cracked all the way round the bottom of the water jacket. Is this a common problem and how can it be fixed? Any other info on Palmer engines would be great. Thanks. SAm in NS
will palmer
07-13-2005 03:29:16
 Re: Palmer Engine, PW-27? in reply to SAm in NS, 06-10-2003 03:29:54
The pw-27 is made up of mainly wisconsin engine parts if you get an old AEH model engine it will march the crank case and you will have an air coled motor thats how the rumer started about palmer made an air cooled motor
Larry from MD
06-10-2003 09:06:56
Yes its a common problem and finding good upper block sections is very hard.However its based on the wisconsen AEH block and some people just replace the upper block with an air cooled one from wisconsen.Go to www.oldmarineengine.com and post on there board if you want to talk to a real expert.If the crack is only to the outside maybe it could be welded or patched,but if used in saltwater its not likely to hold.
