Troubleshoot Magneto
David B. Rankin
06-22-2003 19:35:56
Does anybody know a good procedure for troubleshooting a Fairbanks-Morse X4B7 Magneto? I have replaced the points and condenser with new and still NO SPARK! Point gap is .015 like the manual says. I don't know what to try next. I need to make sure the Mag is creating or not creating spark before I more forward. Thanks.
Larry from MD
06-23-2003 09:31:54
 Re: Troubleshoot Magneto in reply to David B. Rankin, 06-22-2003 19:35:56
If your impulse is working most people would figure the coil is bad.You can test to see if the coil is shorted from the small wires to the post that the spark comes out of.Unhook all the wires and use a continety tester across the small wire to the big post.If you have contact then replace the coil which you most likly will have to do anyway.
