Wisconsin engine
Bill G
07-11-2003 14:46:58
I have an older Wisconsin engine that may be a THD or TJD That I can't identify. It is a two (2) cylinder with the following charistics a generator with the distribitor mounted on the back end of generator and cutout mounted on top, a priming fuel pump (lever on side), a standard bendix starter(looks like one on my CUB tractor), has 12 volt system (resister on coil), updraft carbruator, and exhaust comes out top of manifold.
Would like to know the model, HP , specifications. Or source. Thanks, Bill G
Earl S.
07-18-2003 14:16:28
 Re: Wisconsin engine in reply to Bill G, 07-11-2003 14:46:58
Take spark plugs out .Are both pistons up??Is one up and one down??
Steve-Maine
07-14-2003 02:07:37
Both the THD and TJD used block casting number BA62 after serial number 5472996. BA60 was used on TJD before that and BA51A was used on THD before.
Carb for THD was Zenith L36CS1 (12158) and TJD used L63BLS1 (13694) Model Bore Stroke CID HP THD 3.25" 3.25" 53.9 18 TJD 3.25" 3.25" 53.9 18.2
