Stationary Engines Discussion Forum
Wisconsin V4 Hint
Dell
07-22-2003 18:33:50
After talking with Wisconsin service rep I discovered the distributor rotor turns COUNTER-CLOCKWISE. Then I took cap off and turned engine and sure enough the rotor turned to the left. So when installing plug wires make sure you go LEFT from number 1. Firing order is 1342. Service rep told me firing order is same for magneto and distributor/coil engines.
