Stationary Engines Discussion Forum
International LA
Raymond Bagwell
07-25-2003 08:22:06
I have an International LA engine I am having problems with. When I bought it I put a new condenser in,cleaned the points opened the carb adjuster a 3/4 turn and it would start and run first crank. Then it started to get contrary. You had to open the carb adjuster about 1 1/4 turns. I eventually put a new check valve and fuel line on it. It would start but not as easy. Then I bought a condenser from H & M since the one I had was just an automotive type. The engine is firing a good blue spark. I can squirt fuel in the cylinder and it still will not hit. I could use some advice on what to do next. Thanks in advance for your help.
Red Raider
07-31-2003 06:07:04
 Re: International LA in reply to Raymond Bagwell, 07-25-2003 08:22:06
Check the spark plug wire for breaks in the insulation. I had the same problem as you and discovered some of the insulation had flaked off and caused the spark to ground once in a while. Sometimes a 1/4" wide blue spark, sometimes nothing.
Réjean Lévesque
07-27-2003 07:57:18
Refer to Owners manual (dxf file)
http://www.oldengine.org/docs/
