Stationary Engines Discussion Forum
What type engine
Bill
07-30-2003 15:43:25
Have a pull behind electromagnet to clear construction sights. It has a one cyllinder engine that I can't identify. I do think the first letter is a K but that is all I can make out. I need a carb. for this thing to get it to working again. The carb is a carter. The unit was built in 1958. Works very good but someone damaged carb and I need another.
Thanks in advance Bill
Gene Davis
07-30-2003 20:42:59
 Re: What type engine in reply to Bill, 07-30-2003 15:43:25
Most kohlers had a K prefix for their model #'s
John McPherson
07-31-2003 11:11:14
 Re: Re: What type engine in reply to Gene Davis, 07-30-2003 20:42:59
Kohler's had an external set of points too, not hidden under the flywheel, but rather under the little metal cover that holds the "shutoff" switch.
gene beidler
01-04-2004 09:14:37
 Re: Re: Re: What type engine in reply to John McPherson, 07-31-2003 11:11:14
i have a wisconsin W2 1250 2cyl v need info on timing distributer cant get it to fire on both cyl. anny help would be apreshe ated thanks
