Stationary Engines Discussion Forum
Briggs stratton 3 hp wont start, backfiring.
Don Phillips
08-14-2003 02:04:22
Hi all, I have pulled the old mower out after leaving it sit for approx 4 months. The problem is that it just wont start, it wants to, but after several revolutions of firing it stops and wont start again unless I leave it for a while.
I have checked the spark plug and spark, all ok, however the plug is very wet. I clean it and put it back in and try again after a while with the same results.
I notice that the Choke is closed and when I try moving it manually I hear a faint sucking sound, is this normal?
The last time that I tried starting it was without the air filter and it starting backfiring as it tried to start.
I have searched the net looking for a workshop manual but they are as scarce as....
Any help would be appreciated greatly, thanks in advance all.
Don P.
Gene
09-21-2003 06:02:50
 Re: Briggs stratton 3 hp wont start, backfiring. in reply to Don Phillips, 08-14-2003 02:04:22
I have a B&S lawnmower engine that if you prime the bulb, will start but only run for a moment before it stalls. It seems to run out of gas in the carb. Anyone got any ideas?
thanks,
kent
09-23-2003 09:08:21
 Re: Re: Briggs stratton 3 hp wont start, backfiri in reply to Gene, 09-21-2003 06:02:50
You have something plugging your main jet or pick-up tube. Remove carb and blow out should fix you up.
John McPherson
08-14-2003 09:51:26
Take the flywheel off, and see if the key sheared. It sounds like it should be that simple.
Paul northern lower MI
08-25-2003 19:02:03
 Re: Re: Briggs stratton 3 hp wont start, backfiri in reply to John McPherson, 08-14-2003 09:51:26
Make sure that your valves have the correct clearance and that they are properly adjusted! HTH paul
