Stationary Engines Discussion Forum
Hobart/Hercules Info and Parts Needed
Dave
08-25-2003 08:32:15
How can I determine what herc engines I have? They are in early '40s Hobart 2.5 and 3.0 kva gen units. Is there a serial number list somewhere?
Also need a manafold/carb and starter. I belive they are either the ZXA or ZXB but I do not know how to know for sure which short of opening it up (not perferred) to measure the bore.
Did the ZXA and ZXB use the same basic block and externals (i.e heads manfolds carbs etc.)?
Any info will be appreiciated. Thanks
Dave
Hillsboro, OH
Gene Davis
08-25-2003 19:46:55
 Re: Hobart/Hercules Info and Parts Needed in reply to Dave, 08-25-2003 08:32:15
There is a manual for this engine series on e-bay now; item # is 2552622258. The info you want probably is in it. It only has 22hrs left on the timer, so you might want to look quickly. The BF Avery "V" series tractor used this engine also.
