Stationary Engines Discussion Forum
Gen to Alt conversion
Ned
08-30-2003 10:38:13
I am converting my Lincoln SA 200 welder to an alternator charging system using an older model Ford alternator and regulator. The system also has an ammeter. I have also installed a key controlled ignition switch made for magnetos. I have wired the Bat terminal on the alt to one side of the ammeter and the other side of the ammeter to the bat side of the starter relay. I have wired from the "A" term on the VR to the bat side of the starter relay and from the "S" term of the VR thru the switch to the bat side of the starter relay. Have I missed something?
John McPherson
09-06-2003 09:16:21
 Re: Gen to Alt conversion in reply to Ned, 08-30-2003 10:38:13
The simplest wiring for your alternator is the Battery terminal of the alternator gets attached to the battery(+) easily enough as you have indicated.
With a shunt type ammeter, you can attach the "S" terminal of the regulator to the ignition switch-if the ammeter feeds current to the terminal that you attach the "S" lead to when in the "run" position.
"I" on the regulator is not connected to anything.
"A" Attaches to the batery (+)
"F" Attaches to the field terminal on the alternator.
There is no connection to the "Stator" winding of the alternator.
treeboy
08-30-2003 18:55:06
ned, you may have to post this on the 8n ford board, those guys can wire a space ship, i'm still a greenie when it comes to wiring charging systems, good luck
