Stationary Engines Discussion Forum
Briggs Stratton Magneto
Don
09-02-2003 09:19:27
What gap should exist between the magneto and the flywheel on a 4 HP horizontal shaft B&S engine?
Engine sat in my garage for a couple of years without use and I suspect the lack of spark is due to corrosion that has closed the gap. I cleaned the outside circumference of the flywheel but swear I hear the magneto brushing the flywheel in one spot as I turn the sharft by hand with the spark plug out.
Any thoughts?
Gene Davis(Ga.)
09-02-2003 20:09:26
 Re: Briggs Stratton Magneto in reply to Don, 09-02-2003 09:19:27
.010-.014,if you use a feeler gauge. You can do it much easier and faster with a shipping tag between the flywheel and magnet for a gap gauge.
My Thoughts
09-02-2003 19:24:38
are that if you don't know what you're doing, take it to a repair shop before you tear it up.
