Stationary Engines Discussion Forum
IH model LB stationary engine ( 1 1/2 - 2 1/2
Mark's Toys
09-15-2003 18:53:58
I've recently purchased my first stationary engine which works well but the seller had no operating or maintenance proceedures. I can get it running-- understand throttle, choke, carb adjust knob but need some help w/ maintenance... oil level/ safe water temp / is water ok or should antifreeze be used / any info on flat belt drive ice cream mixers? Mark
marvin valiquette
06-20-2004 05:15:26
 Re: IH model LB stationary engine ( 1 1/2 - 2 in reply to Mark's Toys, 09-15-2003 18:53:58
i
iam looking to purchase 1
Red Raider
09-16-2003 10:48:32
Oil level even with drain plug.
Water temp, anything but boiling.
Coolant, plain water, drain after use and let dry out.
Haven't seen the ice cream freezer, but would like to have one!
third party image
andrew scott
02-09-2004 18:24:25
 Re: Re: IH model LB stationary engine ( 1 1/2 - in reply to Red Raider, 09-16-2003 10:48:32
I noteced thet your la is gray and red and I also hove an la that is almost ready for paint but from some people on another site say it might be the gray one and noteced that yours has no hand throtal control just like my . do you know for shur that yours is the right colors and what year is yours and could you send your searial number so I can compair it to myne and any info would help.
thanks andrew
Jim Johnston
08-31-2004 17:40:06
 Re: Re: Re: IH model LB stationary engine ( 1 1 in reply to andrew scott, 02-09-2004 18:24:25
I have a orginial 1936 LA.My engine is red,flywheel is red.I do not know what color is on top of the wheel,if it was different than from the rest.Jim
Baggsy-Wy
09-18-2003 02:17:55
I'd run just water in it. Antifreeze makes a mess out of things and can mess us your paint job. Too Dam* sticky. Water will work fine, and I don't think boiling is a bad thing. Some of the old engines just seem to run better when warmed way up. Good for boiling eggs in for lunch (grin).
I saw your ice-cream mixers out here somewhere, seems like they were dutch? made, and showed 'em running with a John Deere engine. Try a google search, if no hits, holler back and I'll see if I can find it again. They were pricey though, $1,400 bucks if I remember right...
