Stationary Engines Discussion Forum
how to start 1 1/2 jd e hit miss
Andrew
09-29-2003 19:43:05
HI i got a john deere e hit miss 1 1/2 hspower engine. Dont no much about them just wondering what a guy does to start one of these. What kinda of fuel does a guy use in these is there a way to check the integrity of my magneto on there if possible please label steps on starting it thanks a lot andrew
Baggsy-Wy
09-30-2003 09:48:51
 Re: how to start 1 1/2 jd e hit miss in reply to Andrew, 09-29-2003 19:43:05
I haven't been around one for awhile, but all these old engines are pretty simple. First ensure it is getting fuel to the carb. It burns gas. Make sure the check ball on the end of the fuel line is free and clean. Make sure intake valve is free also. Check spark by pulling wire off ignitor and spin the flywheels while holding wire against ignitor spring. You should see low voltage sparks. Check timing, don't remember what marks are on an 'E', but that might be a good excuse for you to get a manual. There's a butterfly valve to set (I think)...the one I had started up nicely, but another at a show I saw would not start by itself...had to be belted to another engine to get it to fire-up. Keep us posted.
