Stationary Engines Discussion Forum
akn wisconsin with clutch
deano
10-13-2003 17:46:11
I've got this single cylinder wisconsin can't get running..I bought points so have plenty of spark but can't get gas to plug..had carb off/ and cleaned twice everthing looks good. it's a marvel scheib. is there a trick to getting compression built up etc???
Kent of SW MO
10-14-2003 07:00:15
 Re: akn wisconsin with clutch in reply to deano, 10-13-2003 17:46:11
If you do not have any compression, check for a intake or exhaust valve which is stuck open. You may have to pull the head. I have made a fitting where I can put air pressure in the cylinder to find a stuck valve.
dean
10-15-2003 06:11:38
 Re: Re: akn wisconsin with clutch in reply to Kent of SW MO, 10-14-2003 07:00:15
Thanks, intake doesn't appear stuck but think i'm going to remove head/see what's goin on...
dean
10-15-2003 18:35:37
 Re: Re: Re: akn wisconsin with clutch in reply to dean, 10-15-2003 06:11:38
took head off, exhaust valve was stuck! thanks I have it running ....seems to run good...what a difference a little compression makes.....
