Stationary Engines Discussion Forum
wisconsin engine
jack in acton c
10-15-2003 11:44:23
I have a two cylinder wisconsin engine with no ID. on it. All I can see on a label is "MOST H.P.,Wisconsin". Looks like the distributor is on the end of the generator.The cyliners are vertical. It has an oil bath air cleaner and An inch and a half crank shaft. The exhaust maniflod is pointed up with a flat muffler on top. It is electric start and crank. Any one know what it is and If I can get parts for it?
Kent of SW MO
10-23-2003 15:27:25
 Re: wisconsin engine in reply to jack in acton ca., 10-15-2003 11:44:23
It will be a THD or a TJD. If the piston travel together it is a THD. If not it's a TJD
Benj. J. Joe Browning
10-15-2003 19:33:42
Hello Jack, Your best bet is to call the factory @800-922-5632. Ask for Hike (ext #6) Give him the casting number off the block. He's very good at "ID"ing engines. Hope this helps Joe
Paul Burows
10-15-2003 17:07:28
What it is I don't know. However Continental engines owns Wisconsin now and their web site has a variety of parts as these are very common engines. Good luck.
jack in acton ca
10-15-2003 22:01:16
 Re: Re: wisconsin engine in reply to Paul Burows, 10-15-2003 17:07:28
Thanks JB and PB for the info.I'll check it out.
