Stationary Engines Discussion Forum
Need 4-cyl diesel, from thermoking
Richard
11-07-2003 19:39:48
howdy,
I have an old ThermoKing genset I'm trying to get running for the cabin where we live (no power lines here).
It has a Mercedes OM636 4-cyl diesel which threw a rod through the block. I saw another identical unit which used an Isuzu C201 engine. I think the bellhousing pattern might be the same; i.e. some kind of SAE standard for this size motor.
The local Thermoking dealer offered me a used motor for 400 bucks, but I don't have that kind of coin right now.
If anyone has either brand/model engine, running, that you'd part with cheap, please do email me. I'm in SW Oregon, but may be able to arrange cheap freight via a trucker friend.
PS; If you have a non-running OM636, I might be able to use that too, so long as it's mechanically OK. I.e., if it's just an injection pump problem, I could swap the pump off this blown motor.
thanks guys!
Richard
Clay Gormish
12-18-2003 13:32:25
 Re: Need 4-cyl diesel, from thermoking in reply to Richard, 11-07-2003 19:39:48
Mr. Troyer at Troyer engine & Repair has many of these for parts. I used one for a 20 k generator and he supplied a parts block, as I had a bad cam in the one that I had purchased on E-bay.
His phone number is 330-897-2805.
He is in central OH.
