Stationary Engines Discussion Forum
Onan 24 motor (driving me crazy)
Frank
11-08-2003 12:58:01
Have this Onan 24 twin cylinder engine. Starts up, runs good for about five minutes, then stalls , no spark at plugs,there is fuel at carb. Leave it sit for a few minutes starts right up again,same proceedure. Got new coil ($250.) and condenser Still does same thing. Checked for loose wiring and conections, none. Any ideas. Thanks Frank
Bob
11-24-2003 14:23:14
 Re: Onan 24 motor (driving me crazy) in reply to Frank , 11-08-2003 12:58:01
For what it's worth, I have a couple of Kohler and Onan twins, and both of them are sporting Harley Davidson coils. The original on the Kohler looked exactly the same (both made in Wisconsin, I guess), and on the Onan, while it looks a little different, electrically it is the same. I think Harley went to electronic ignitions sometime in the late 70's. My bike is a 76 and still has points, so any Harley coil 76 or earlier should work for sure.
Baggsy-Wy
11-09-2003 21:25:54
Classic symptoms of a bad coil, heats up, shorts out, dies, cools down, starts right up. I can't believe a new coil costs $250!!! My best old engine didn't cost that much? Do you have a multimeter? Or have access to a condenser/coil tester? You say you have fuel, but I've seen tank breathers clogged and do the same thing. Not sure what to tell ya, except find a place with cheaper coils. Have you switch plugs out to see if that could be the problem? Let us know cause I'm interested in what it might be now...
Kent of SW MO
11-11-2003 11:41:39
 Re: Re: Onan 24 motor (driving me crazy) in reply to Baggsy-Wy, 11-09-2003 21:25:54
Onan parts are costly. $250 for a coil is not a big surprize.
