Stationary Engines Discussion Forum
Lister LD1
David
11-14-2003 06:45:38
Got my mates engine turning and injecting fuel but there's not a kick out of it. All I have are six blisters from trying to start it. I have tried heating the manifold and cylinder with a blow lamp, putting a little petrol, meths, cellulose thinners, diesel and oil into manifold. It just won't attempt to fire. Next idea is to put a belt on a drive it from another engine to see if it will run. Oh, I will try ether too, just didn't have any to hand at time. Has anyone got any other good ideas? Don't think I'll be spending any money on it but it would be nice to see it run.
ScottS
11-22-2003 09:05:39
 Re: Lister LD1 in reply to David, 11-14-2003 06:45:38
I have never seen one of these in person. Here is a site I hope will help you. I am not associated with these folks in any way.
Kent of SW MO
11-14-2003 08:50:43
Does it have compression? Is the injector pump in time? If no compression, Does it have a decompression release which might be stuck in the on position.
David
12-08-2003 04:37:43
 Re: Re: Lister LD1 in reply to Kent of SW MO, 11-14-2003 08:50:43
Yes, its got compression but I thin its low becasue of wear, decompression lever is working ok. I think pump timing is ok as there isn't much scope for adjusting it. Fine adjustment is by shims and I have it back together as it was when it last ran. I think its just too worn. I'll try turning it with another engine sometime.
