Stationary Engines Discussion Forum
Information on Hobart Generator
Kim
11-29-2003 13:32:07
I just purchased a generator made by Hobart Brothers in Troy,Ohio. The plate says: unit ac gasoline, electric generating m5, 30 kva,125 volts 50/60 cycles. it was mfg. 1942, and has a Herculies ZXB 4 cylinder motor. Anyone know where I might find a book on it, or any info? Any idea what it could be worth in working condition? Thanks for any help, Kim
Scott from Oregon
12-23-2003 10:06:42
 Re: Information on Hobart Generator in reply to Kim, 11-29-2003 13:32:07
Hi Kim,
The M5 and M6 generators are WWII military units that were used to power a 37mm anti-aircraft gun control system. Their main power output was three phase, but they do have a single phase auxillary output. That little ZXB engine put out about 11 horsepower.
The technical manual for the generator set is "TM 9-616,Generating Units M5 and M6 (23 December 1943)". If you do a google search for 'TM 9-616' you will find quite a few sources for it.
Good Luck,
Scott
Bill Craig
12-03-2003 16:30:47
Kim, You might try Hobart Bros. Co., (still in Troy, OH) at 937-332-4000. They may not have the info, but someone there should know who might. My neighbor retired from the ground power division 2 years ago, but he's on vacation for a couple of weeks. Let us know if you find out anything!
Bill C.
Larry from MD
12-02-2003 17:11:08
If the generator is bad some of the fellows with avery or moline model V tractors might want the engine.
