Stationary Engines Discussion Forum
Need 3 1/8 piston for Onan BF MS/2379B 16 hp '70s
Larry
12-18-2003 22:52:21
I need a nos or good used standard piston for an Onan BF MS/2379B twin cylinder engine used on a Sears 16/6 Twin Garden Tractor.
The piston is a 3 1/8" diameter. Later engines use a 3 1/4" piston. Onan no longer makes or supplies these pistons. I hope someone will have or know a source for one or 2 of these. Only need one now but operate two of these tractors and wouldn't mind a spare.
Thanks.
Larry deep in TX
jstrick
06-17-2004 04:09:46
 Re: Need 3 1/8 piston for Onan BF MS/2379B 16 hp ' in reply to Larry , 12-18-2003 22:52:21
I have the same problem. A freind borrowed a sears tractor from a friend of his and the motor blew. I havn't been able to find a piston either
mbeck
03-13-2005 04:34:56
 Re: Re: Need 3 1/8 piston for Onan BF MS/2379B 16 in reply to jstrick, 06-17-2004 04:09:46
Good luck, you can get it bored out to 3.25 and get pistons that way. I need a rod for the same engine.
thanks
mike
