Stationary Engines Discussion Forum
12 HP Cray and Son's
Spoker
12-26-2003 07:55:48
I have a 12 HP Cray and Son's that is Hopped cooled. It is built simular to a Waterloo Gas Engine. It has a Tag that says Cray and Sons Chicago Il. Pat. Date 1907. Do any one of you know any thing about this engine. I know it weight is 2,080 lbs. Who built this engine and was there many built. I have seen one 10 hp at Republic Mo. Show and a 6 hp that came out of a concrete mixer. It has a Brass Lukenhimer mixer and has an ignitor. Any Help would be appreciated. I have looked in the Gas Engine Books and have not seen the Cray and Sons mentioned. (older book) Thank you for the info in advance.
Frank Eddy
12-31-2003 20:32:32
 Re: 12 HP Cray and Son's in reply to Spoker, 12-26-2003 07:55:48
Do you have the serial no. and type. It would help if you could post or send a picture of it. I have a 12 HP John M Smyth which should be the same as your engine. Is the govener in the flywheel or a flyball?
Bill D.
12-27-2003 22:05:17
I've found reference to Cray Brothers Co. Cleveland, Ohio. They were a large jobbing house that got their engines from Waterloo, Iowa. Quite possible the two companies were some how connected.
Spoker - Thank You
12-28-2003 07:03:22
 Re: Re: 12 HP Cray and Son's in reply to Bill D., 12-27-2003 22:05:17
For this info. I have only seen a 10 and a 6 hp, and I own this 12 Hp. I can get it to fire once in 36 seconds when it is running. This might be a bit too slow. Thanks again for your information
Bill D.
12-29-2003 06:10:15
 Re: Re: Re: 12 HP Cray and Son's in reply to Spoker - Thank You, 12-28-2003 07:03:22
The info I have lists Cray Bros. as making a 1 1/2, 2 1/2, 4 1/2, 6, 8, 12 hp engines. Some people strive to get a hit & miss engine run that slow. Is there a reason you would want it to run faster? As long as it stays running I don't see a problem.
