Stationary Engines Discussion Forum
Wisconsin V440 engine will not start!!!
Eddie
01-06-2004 02:28:17
Hi everyone,
I have a problem getting a Wisconsin 40 Hp motor started. It is used on a concrete cutting saw.
I decided to change the battery on my Meco 40hp flatsaw today since it was starting to die out. I put the positive lead on the positive terminal of the battery and started tightening the nut up with my wrench. While doing this, I accidently touched the negative terminal of the battery and it made a big spark.
Without any concern, I hooked up the negative lead to the negative terminal and tried to start her up. But nothing. The starter didn't even start cranking. The gauges were all dead. So, I decided to start the starter up with my screwdriver. But all I hear is the cranking. It won't start up.
What is wrong with this? I thought maybe the ignition switch went bad so I changed that and still nothing. Any suggestions.
Shannon
01-18-2004 20:03:24
 Re: Wisconsin V440 engine will not start!!! in reply to Eddie, 01-06-2004 02:28:17
Recheck connections on switch,If that fails look for a burned out fusible link or wire....
rod
01-06-2004 13:21:44
try running jumper wire right to ign coil -if starts then you blew out starter solinoid
