Stationary Engines Discussion Forum
5 hp BS
Ron
01-06-2004 18:37:41
Hey Guys, I have a 5 hp Briggs & Stratton engine sitting on a log splitter. It will only run at full choke, then quits under load! All ideas and suggestions will be very much appreciated! TIA Ron.
John McPherson
01-07-2004 12:10:58
 Re: 5 hp BS in reply to Ron, 01-06-2004 18:37:41
It may be diaphram. If it is one of the pulsa-jet types. Otherwise while it is running (and not hot) spray a little carb cleaner or WD40 at any and all potential spots where a vacuum leak might appear, such as mounting flanges, etc. If nothing shows up there, check compression, as well as the condition of the flywheel key as it may have sheared.
What kind of compresion does it have right now? If it is on the weak side, you might want to take a look at the valve seats and restake them to make sure they are not loose.
Ron
01-08-2004 05:34:51
 Re: Re: 5 hp BS in reply to John McPherson, 01-07-2004 12:10:58
Great responce! Thanks, John! Ron
