Stationary Engines Discussion Forum
updraft carb on exhaust manifold
frank s
01-18-2004 11:30:35
seen a wisconsin 2 cyl, with updraft carb connected to ex manifold, how does gas/air mix stay out of exhaust? downstroke of piston sucks mix i know, please end my confusion thank you,i put in search on yahoo and found that updraft carbs on aircraft helps keep carbs from icing.so i see that the mix is preheated by this how is the exhaust kept seperate?
Bob
01-18-2004 13:19:46
 Re: updraft carb on exhaust manifold in reply to frank s, 01-18-2004 11:30:35
There is a separate intake passage. The intake and exhaust passages are not connected.
