Stationary Engines Discussion Forum
What is this generator?
Harrison
02-07-2004 14:47:13
I posted a picture of a generator head in the HELP IDENTIFY section.Any help would be greatly appreciated.I spun that thing at about 1200 rpms with a side shaft motor the needle moved but did not go far enough. I'd like to put brushes and bearings in it before I mount it.I don't have no idea how many kw it is,but I do know it is heavy.25 1/2" around the center,11 1/2"Long not including shaft.It has bearings at both ends.
Kent of SW MO
02-08-2004 15:46:29
 Re: What is this generator? in reply to Harrison, 02-07-2004 14:47:13
I do not know the brand of generator, but most A.C. generators need to be turned 1800 or 3600 RPM. As big as it looks in the picture you are going to need 15 or 20 HP to pull it at full output.
