Stationary Engines Discussion Forum
Fairbanks Morse Z 1 1/2 hp,battery ignition
Keith Ault
03-04-2004 15:46:54
need head,crankshaft bearing cap and crank handle.The head is cracked between outside and water jacket,repair not affected by compression,will drilling.cutting a "V" and using JB weld work or should I have it welded/brazed thanks
Bob
03-12-2004 13:18:56
 Re: Fairbanks Morse Z 1 1/2 hp,battery ignition in reply to Keith Ault, 03-04-2004 15:46:54
There are used parts readily available for these. Why not search around for a used head? That way it's fixed first time around!!
