Stationary Engines Discussion Forum
3 HP Briggs starting Problem
Derek
04-04-2004 10:40:28
I recently got an old Atlas roto-tiller from my in-laws barn. It hasnt ran in about 3 years. Took it home, cleaned it up etc...
The only way I can get it to run is if i poor a bit of gas right in the carb. Then it will run fine all day if you want. I can pull it until my arm falls off and it wont start unless I manualy throw some gas in the carb. Seems wierd because if i gettted started that way like I said it will run fine after that...
Any ideas? Is there a chance there is a problem of the fuel getting to the motor on start-up??
Thanks for any help..
Brian Decatur co. Ia
04-10-2004 21:39:20
 Re: 3 HP Briggs starting Problem in reply to Derek, 04-04-2004 10:40:28
If it has a pulsa-jet carb, the upper cup in the tank may have a pinhole draining the gas back to the main tank. The pulsa-jet has a pump that keeps the upper cup full so the fuel mixture doesn't need to be adjusted as the fuel level drops in the tank. The pulsa-jet has a plate on the muffler side of the carb. The vacu-jet carb has a check ball in the dip tube to keep the fuel in the jet of the carb while cranking to make starting easier. A small piece of crud can stick it open and let fuel drain back.
