Stationary Engines Discussion Forum
Wisconson TJD govenor
benjy bertossi
04-10-2004 05:56:03
After rebuilding a TJD (govenor was not removed) there seems to be lots of gear noise coming from govenor when engine is running. Fearing there is something wrong, what may I do to determine if this noise is a problem or normal sounds? Thanks in advance for any responses.
Bob McDermaid
04-10-2004 09:20:17
 Re: Wisconson TJD govenor in reply to benjy bertossi, 04-10-2004 05:56:03
I am pretty sure there is an oil spray nozzle in the timing case some where at the bottom i think and there is also an oil line to the governor with a restriction in it that may be blocked
