Stationary Engines Discussion Forum
Wisconsin AENLD Engine Question
Don Allen
04-18-2004 03:48:53
Wisconsin AENLD, Serial# 4193374, Spec# 276104, 3" X 3.25". Can anyone tell me if there is any other option for this engine other than the wrap-the-rope pull start? I am looking for some other kind of setup. Also, I cannot get this thing to start. Thank you
Zira
04-18-2004 16:04:58
 Re: Wisconsin AENLD Engine Question in reply to Don Allen, 04-18-2004 03:48:53
Wisconsin offered a belt-drive starter/generator set up, a regular bendix-type starter with seperate generator (requires a different flywheel with ring gear), and a recoil starter. The recoils was offered as an add-on, and the starter-generator can be added if you are not scared to drill & tap holes in the block. I second the recommendation to get an older manual. E-mail me off-line if you need a scan showing these set-ups.
Benj. J. Joe Browning
04-18-2004 14:17:29
Hello Don, On your question. I would approach it from several ways. First; get on Ebay and get one of the older service manuals. They are better,cheaper then new usually, and show a lot more detail. This should help you to get your engine running. Second; Review some of the earlier posts. There are several individuals that have loads of knowledge about your engines. Also a number of supplier contacts. Third; Parts #1 Contact- Rock Creek Consulting (wisconsinengines@eartlink.net) He has lots of parts, both new and used. He is very good to work with on obtaining parts. #2 Try the factory. 800-922-5632 ext #6. Ask for Hike. He also is a good knowledgeable individual that will help you alot. #3 Try Ebay. Enter Wisconsin Engine. Usually a lot of items for sale. Hope this helps, Benjamin J. "Joe" Browning
Bob
04-18-2004 13:48:46
I'm not sure what Wisconsin offered, but if you're looking to use it and not restoring it to original, a belt-driven starter/generator off of a Briggs or Kohler should not be to tough to attach to the engine.
Here's a link to a photo of one on ebay. (I have no connection to this auction.)
