Stationary Engines Discussion Forum
Kohler KT19 blowing oil
Brian
05-04-2004 18:03:13
I have a mid-80's KT19 (with the square air filter housing) on a Bolens 1900. When the idle is turned up it blows oil out of a rubber tube that sticks up from the engine block. It reminds me of a tube that would have a PVC valve on top of it, like I had on an old Mustang. Anyone have any ideas??? My next step is to take it for a tune up, but I'd like to have an idea of what I'm getting into. I can email a picture if it would clarify what I talking about. thanks!
Jim Rode
01-08-2005 22:06:21
 Re: Kohler KT19 blowing oil in reply to Brian, 05-04-2004 18:03:13
I have a Bolens 1900 with a Kohler KT19QS. I started it up and it started smoking. Shut it down and found the air cleaner housing filled with oil. Took everthing apart and started it up again and after about a minute oil starts shooting out what I believe it is "oil breather hose". How do you fix this? What"s causing it? Any help would be appreciatd.
Thanks.
Bill Klein
05-04-2004 19:56:31
The breather tube has no valve in it but the breather unit it comes out of does. The original flapper was a rubber disc which is known to shrivel from the manifold heat or come out of place. New breathers are made with a metal reed instead. Also check the crankshaft seal. Often the seal will come loose, sometimes due to a faulty breather and sometimes just on it's own. Bill Klein
