Stationary Engines Discussion Forum
Continental F163 or F162 4 cyl. gas Engine
Paul
05-14-2004 18:25:20
How do you tell the difference in a 162 and a 163?
justin
05-27-2004 13:53:29
 Re: Continental F163 or F162 4 cyl. gas Engine in reply to Paul, 05-14-2004 18:25:20
i know the mains are alot heavier on the 163 but not sure if its the only difference.
J.
05-15-2004 18:04:58
I do not know exactly what you are getting at. I do not have casting numbers right here, but the difference is internal. I know when I got involved with a certain gasket manufacture the head gasket had to be changes a little bit because of the changes. Right now my mind just went blank but I think the center main is now the thrust and that is why the distributor had to move. Interesting the 227 we looked at had a 226 casting number and it had been ground off, but it was a 227 with a flanged thrust.
Greg Webb
01-26-2005 17:48:39
 Re: Re: Continental F163 or F162 4 cyl. gas Engine in reply to J., 05-15-2004 18:04:58
Anyone know if flywheel, intake and exhaust manifolds, and distributor will interchange?
