Stationary Engines Discussion Forum
Wisconsin TJD Fuel Pump Kit
HWooldridge
05-21-2004 11:40:17
I have a Wisconsin TJD 2 cyl engine and need either a fuel pump kit or a complete fuel pump. The diaphragm is there but stretched out so does not pump efficiently. Does anyone still stock kits?
Gene Davis (Ga.)
05-23-2004 19:36:02
 Re: Wisconsin TJD Fuel Pump Kit in reply to HWooldridge, 05-21-2004 11:40:17
Had a friend with a tjd engine and his fuel pump diphragm split dumping gas into oil, after looking at the price of a new pump from dealer,I installed a small electric pump from NAPA parts store for about 1/2 the price and made block off plate for the old pump and wired it to distributor side of ignition switch and all went well.
Kent of SW MO
05-22-2004 12:41:37
I was having fuel pump problems with my Dad's Kohler K 301. I rounded up the fuel pums I had around. One from a K301, one from a Wiscon THD and one from a Kohler KT-17. The pump arms on the THD and the KT-17 look near enough the same to be interchangable. Also the diapharams look to be the same on the THD pump and the K301 pump. The Kohler pump kit for the K301 pump is Part No. 230675-S. The valves are differant in the two pumps.
