Stationary Engines Discussion Forum
engine overheating
Jeff
05-25-2004 18:50:59
I have a 18 hp wisconsin engine that over heats and shuts down when mowing I've checked for mouse nests and havent found anything to block the cooling. It was just rebuilt two years ago and has run fine ever since. can you help!
Bob
05-25-2004 20:33:36
 Re: engine overheating in reply to Jeff, 05-25-2004 18:50:59
Does this engine have a temperature switch in the head that shuts it down, or does it stop for no apparent reason?
If it is actually shutting down due to the temperature switch (and the switch isn't defective), the most likely causes are restricted cooling, or late ignition timing.
jeff
05-29-2004 20:19:20
 Re: Re: engine overheating in reply to Bob, 05-25-2004 20:33:36
Ok now how do i check the timing I've never messed with anything like this. hope you can help. Thanks Jeff
