Stationary Engines Discussion Forum
Wisconsin VF4D firing order
Glenn
05-28-2004 17:30:32
I am rebuilding my VF4D engine and am having trouble with the timing/firing order. The cylinders numbers are:
4 2
-----Flywheel
3 1
I have the distributer and it seems the 2 cylinders on the same side firing consecutively which seems wrong to me. Can somebody help with the firing order and how I would wire the distributer. Thanks
Benj. J. Joe Browning
05-28-2004 20:53:31
 Re: Wisconsin VF4D firing order in reply to Glenn, 05-28-2004 17:30:32
Hello Glenn, I have the Service and parts manual for your engine. The timing order is 1,3,4,2. On the distributer, please send me a Fax number and I will send the info that I have. You also might try the factory @800-922-5632 Ext #6. Ask for Hike. I would also get a older manual off Ebay. They are better then the new ones, with more detail. Hope this helps, Joe
Glenn
05-29-2004 04:36:24
 Re: Re: Wisconsin VF4D firing order in reply to Benj. J. Joe Browning, 05-28-2004 20:53:31
Joe,
Could you email me your email so I can send you my fax number?
Thanks for your help.
Glenn
Richard3
11-28-2004 10:03:30
 Re: Re: Re: Wisconsin VF4D firing order in reply to Glenn, 05-29-2004 04:36:24
Have technical manual VH4d series
