Stationary Engines Discussion Forum
Lister-Petter AC1 Diesel Engine Injector Pump Ques
Howard Yoshida
06-25-2004 21:34:39
Aloha, I have an ex-military Lister-Petter AC1 6.5hp one cylinder diesel engine that powered a portable heater. The engine has 29hrs on it but it won't start. I want to remove the fuel injector pump from the engine block to clean it out. Is it gear driven or does it work off the cam lobe? I tried pulling it out but it only comes out about 1/4" so I stopped. If it is gear driven, how is the timing set to the pump?? If it is tappet driven, what is keeping it from coming out?? All sugestions will be appreciated.
Mahalo,
Howard
Ed Zapel
10-24-2006 15:44:19
 Re: Lister-Petter AC1 Diesel Engine Injector Pump in reply to Howard Yoshida, 06-25-2004 21:34:39
You must remove the end plate and put the fuel rack in a centered position before the injector pump can be removed. I tried to remove the pump from an ac1 without centering the fuel rack and the rack hung up on the engine case which bent the rack. I had to drill out the rack to remove the pump and now need to find another injector pump. The pump is a Bryce model FAOAR 055E0851 Serial number AH 02025. It was mounted on a Lister-Petter engine No 40-02814. Perhaps someone can tell me where to get another pump for this engine.
ED ZAPEL
10-30-2006 16:47:15
 Re: Lister-Petter AC1 Diesel Engine Injector Pump in reply to Ed Zapel, 10-24-2006 15:44:19
I really need to find either another injector pump or another AC1 engine
JV
01-05-2006 14:45:46
Hi Howard. If this is still giving you bother, I found that the pump on these engines tends to hank on the end of the rack. Try gently moving the stop control lever. About halfway through the lever travel the pump should slide out freely. If not you may have to remove the timing cover and work the rack manually. If the engine has been lying for a long time it is common for the rack to stick in the STOP pos.
Cheers, JV.
MIKE SCHMERL
05-06-2006 19:47:39
 Re: Lister-Petter AC1 Diesel Engine Injector Pump in reply to JV, 01-05-2006 14:45:46
i recently picked up the same set up. iam missing the starter and a manual. ny help would be great.
booger
10-21-2004 17:50:05
Aloha; To get the pump you must take the fittings off first. I have the same problem if you get yours fixed, please share some tips with me. thanks
Dave
07-10-2004 21:39:28
Howard, in regardto your question on fuel injecter pump it does work off ofa cam. for really good instructions go to www.utterpower.com i hope this help's Dave
vincey
12-13-2004 12:30:22
 Re: Re: Lister-Petter AC1 Diesel Engine Injector P in reply to Dave, 07-10-2004 21:39:28
mine don't go either,,,,bugger
