Stationary Engines Discussion Forum
McCormick Deering Kero/Gas Stationary Engine
Grant Shepherd
06-28-2004 17:00:49
I have a 3hp engine with the serial number BW36629 (not too sure about the "BW").
Am seeking information on the engine and particularly the carburettor for restoration purposes. The engine runs but slows down after 1/2 a minute and it's not long enough to play with the settings. There are three controls on the carburettor all of which can be adjusted by control knobs but i'm not sure where they should be set. Any information would be greatly appreciated. Thankyou.
Chris
07-26-2004 08:24:26
 Re: McCormick Deering Kero/Gas Stationary Engine in reply to Grant Shepherd, 06-28-2004 17:00:49
That engine is designed to start on gas and when hot switched to kerosene. There is a needle valve for both. The third valve is for injecting water into the carb to prevent kerosene detonation(engine knock). I don't know much more about these but you will find better help at www.enginads.com. Click on Smokstack- Its a forum where you can ask questions. This site is entirely dedicated to antique flywheel engines and has a lot of experianced people that can give you some help.
magoo
09-01-2005 16:30:57
 Re: Re: McCormick Deering Kero/Gas Stationary Engi in reply to Chris, 07-26-2004 08:24:26
i recently bought an old engine, sounds like it is very same as yours. but this one is rough. could use help, don't quite know where to start. it appears that you started a while ago, hope i'm not to late.
thanx in advance
pm
