Stationary Engines Discussion Forum
Fairbanks morse model z dishpan
andrew
07-10-2004 18:21:47
I've just bought a Fairbanks Morse model z "dishpan" 2H.P. I was told it is called a dishpan because the flywheels are solid. I know very little about these engines. I have not seen it yet, "only pictures" or heard it run. The person I bought it from knows nothing about this engine either. They tell me that the tag says 600 RPM. My question is is this engine a hit and miss or a throttled engine?? also it has a battery box and coil mounted on the side for the ignition. thank you
Greg LaSota
08-28-2004 06:28:42
 Re: Fairbanks morse model z dishpan in reply to andrew, 07-10-2004 18:21:47
Hey Andrew !
It sounds like we are both in the same boat.
I have the same engine, I just bought it in Dec.2004 Im trying to date it with serial number 627897 Im just getting started also and am already hooked!
gido kriel
09-12-2004 12:20:53
 Re: .starting of fairbanks morse in reply to Greg LaSota, 08-28-2004 06:28:42
can anybody please give me advice,i do have a problem to get a fm started.on a normally cranck with the cranckhandle i cant get it started but when i apply a higher speed . to the pulley it starts and runs smoothly
Bob Hall
08-15-2004 13:05:26
It is in fact a hit and miss, however, it is throttle governed..it gives you the ability to speed up the rpms...but it does not fire every revolution... it fires...and turns about 2 times, and fires again.
Bob Hall
Tom
07-11-2004 09:10:11
Go to www.enginads.com and post your question on the SMOKSTAK forum. You'll get more info than you imagined.
