Stationary Engines Discussion Forum
F/M 11/2 hp,battery ignition timing
Keith Ault
08-20-2004 05:19:19
need help in getting this engine timed and also a copy of wiring diagram thanks
Bob
08-23-2004 10:30:16
 Re: F/M 11/2 hp,battery ignition timing in reply to Keith Ault, 08-20-2004 05:19:19
Ignition info HERE:
Link
(Select the type of ignition info you need in the box at the upper left)
The engine should fire AT or just after TDC so it doesn't "kick back" when starting. Some engines have a lever in the ignitior trip mechanism that you move once it's running to make the spark earlier.
Does it have high tension battery ignition with a spark plug, or low tension battery igntion with an ignitor?
keith Ault
09-18-2004 19:38:51
 Re: F/M 11/2 hp,battery ignition timing in reply to Bob, 08-23-2004 10:30:16
It has high tension with spark plug.It has marks on flywheel and marks on cam gear,still will not run when the marks are aligned help!!!!!
