Stationary Engines Discussion Forum
Clinton Engine Info What year?
gdtractor
09-13-2004 11:52:47
I have an old Bolens garden tractor with a Clinton engine .... it has these numberson it:
serial number 37178A
model number B762COA
any info you can give me would be appreciated.
Thanks much ..
Gary
Roe B. Lane
11-09-2004 19:10:06
 Re: Clinton Engine Info What year? in reply to gdtractor, 09-13-2004 11:52:47
Gary: I have parts book for the B-700 series motor the B-762-COA is included, It was made prior to 1953 as that is date on parts book.
Can send you copy for $5.00 which includes S & H. If you would like. Let me know. roeb@compu.net
Paul Pitcher
10-04-2004 06:57:42
HI Gary,
You have a B700 series motor, 2.5 hp, produced from the late 40s. The block is likely to have a casting date on the PTO side, in a raised rectangle measuring about 0.5" by 1.5". It has a 2" bore and shares the same camshaft and valves with many of the later engines using a similar block. Clinton production moved from Clinton, Michigan to Maquoketa, Iowa in 1948.
Paul (Maquoketa, Iowa native)
Brian Decatur co. Ia
09-14-2004 10:23:20
This must be a walk behind tractor? The B700 series Clinton is pretty small. 2hp at 3600rpm. Yours has a gear reduction on it. Early to mid 50's is the best guess I can make. There isn't any production record for Clinton like Briggs & Statton has.
