Stationary Engines Discussion Forum
Clinton Ignition
Grant Hollingsw
09-17-2004 10:28:47
I am restoring a Clinton engine. It is model 410-054-0165 The coil has 2 wires besides the plug wire coming from it. The condensor has one wire. I think the condensor wire and one of the coil wires go together somewhere, but I'm not sure where. Also, where does the other wire go? One more thing, It didn't have a kill wire on it when I got it, so can you tell me where it hooks up. Can anyone please help me with this problem?
Kent of SW MO
09-17-2004 11:09:13
 Re: Clinton Ignition in reply to Grant Hollingsworth, 09-17-2004 10:28:47
One wire, normally the short one goes to engine ground (the block). The other wire goes to the insulated side of the points to which the wire from the condenser goes. You can also connect another wire to this point to use as a kill wire which you would connect to engine ground to kill the engine. If the engine does not run right switch the wires from the coil as polarity of the coil does matter
Kent
