Stationary Engines Discussion Forum
John Deere E manuals, parts, etc.
JWall
09-19-2004 16:55:26
My dad left me an E engine (#241417), I would like to re-restore it, it does not have a magneto but runs well with a battery and a coil (a piece of pvc pipe filled with something). Should I try to get a magneto? I don't understand how the coil works. I would like to find a manual on restoring the engine etc.
Bob
09-19-2004 20:07:45
 Re: John Deere E manuals, parts, etc. in reply to JWall, 09-19-2004 16:55:26
Reprints of the original literature come up on ebay from time to time. Parts and information are available from a couple of vendors HERE:
Link
You apparently have ignitor ignition with a low-tension coil. The original magneto is a bit finicky, and timing of the mag to the engine, along wtih the ignitor trip is CRITICAL.
Here's some ignition info:
Link
http://www.old-engine.com/maglma.htm
Ole
09-19-2004 18:11:22
Hi
From what you said, the coil you speak of is called a reactor. The engine has what would be the points inside the cylinder. as they break they act the same as a plug. economy engines use this scheme too.
