Stationary Engines Discussion Forum
High/low resistance sparkplug cables VG4D
David Waugh
09-19-2004 21:10:08
On a Wisconsin vg4d I just replaces the only plug cables that were high resistance carbon with copper cables. The guy at the parts store said the copper would be give a stonger spark. Is this true? Why would the factory cables be high resistance if copper is better? I know my car is supposed to have high resistance cables?
-dw
Bob
09-19-2004 21:30:00
 Re: High/low resistance sparkplug cables VG4D in reply to David Waugh, 09-19-2004 21:10:08
Resistance wires are for radio noise suppression, and can cause weak spark at the plugs when used with magnetos or 6 Volt systems.
If your engine is 12 Volts, with good points and coil, it should work fine with either type of wires.
David Waugh
09-20-2004 06:19:04
 Re: High/low resistance sparkplug cables VG4D in reply to Bob, 09-19-2004 21:30:00
Bob, Thanks for the reply. I'm glad the the new ones I bought will work.
-David
