Stationary Engines Discussion Forum
Wisconsin vg4d VERY hard to start
David Waugh
09-22-2004 17:35:16
Ok, so my job is get this 1990 VG4D on a drill rig running. I can't get it to start so I: rebuild carb., new plugs and wires, and
cleaned all starter contacts. I think it has a weak, and maybe intermittent spark. I rebuilt the carb today, and tried starting it. It kept turning over, puff..pufff real slow and then died. Finaly after about 10 minutes I started and ran great! I let it run for about 10 minutes and then shut it off because I noticed some oil leaking from the oil filter. I tried to restart, but it wouldn't go, puff....puff....puff. The engine has sat for about 3-4 years.... My first guess is bad gas. I am planning on getting new points and condenser. Any ideas? could bad gas cause this problem? Condenser? The engine only has 40 hours on it, most of those may be cranking...
Many thanks
Daivd
