Stationary Engines Discussion Forum
Maytag model31 mated to ice cream freezer
Sharps-Nut
10-01-2004 09:05:05
I have had an interest in doing this for years and have started the process. Has anyone out there been there done that. Idea's on will it work or why it wont work. I scrounged up a gear reduction that is 9-1 that should allow me to reduce the 1000 rpm motor to a managable speed. The motor is rated 3/4 horse that should be eneogh to run a 6 quart freezer, woulldn't you think. The missing link came in the form of a 1.00 ice cream hand crank freezer last saturday at a garage sale. Idea's are needed on stall mechanisms or shear pins to prevent turning my 1.00 freezer wrong side out. Help
Gene Davis (Ga.)
10-01-2004 21:31:42
 Re: Maytag model31 mated to ice cream freezer in reply to Sharps-Nut, 10-01-2004 09:05:05
Some sort of a spring loaded slip clutch would be nice so you could set it for the torque rate slippage when cream freezes. Gene Davis
