Stationary Engines Discussion Forum
Wisconsin THD Sticky Valve
Bill Narby
10-05-2004 16:40:58
Thanks to all who helped me. Now the Wisconsin is running and welding. There is still a problem. It had a very stuck exhaust valve, which I got unstuck with Gunk Engine Cleaner. Now when I weld about a stick and a half, the engine apparently warms up a little, and the valve starts sticking, causing a miss and loss of power. Any help on this? I would rather NOT pull the head off.
Thanks, Bill Narby
Kent of SW MO
10-06-2004 06:58:09
 Re: Wisconsin THD Sticky Valve in reply to Bill Narby, 10-05-2004 16:40:58
Run some MARVEL MYSTERY OIL in the fuel. Also a high detergent motor might help. Be sure you have the valve clearances set right. Your valve clearances might be tightening up when it gets hot. Set the exhaust valve clearances on the high side of the specs.
Kent
Bill Narby
10-06-2004 11:29:10
 Re: Wisconsin THD Sticky Valve in reply to Kent of SW MO, 10-06-2004 06:58:09
Thanks, Kent for your help. I am presently running three gallons of 93 octane gas with 8 oz of Marvel Mystery Oil. Only have a few minutes running on this. An old welder told me to set the welder to about 5 or 10 amps, and short the cables together, and run it this way to make a load without hurting the welder. I am going to try that for about a half hour
ronnie269
12-03-2005 19:39:44
 Re: Wisconsin THD Sticky Valve in reply to Bill Narby , 10-06-2004 11:29:10
MARVEL MYSTERY OIL
