Stationary Engines Discussion Forum
Blowing coils on Briggs 5hp
Preston
10-23-2004 21:12:14
I recently bought an old masport rota-hoe with a Briggs & Stratton 5hp engine - 131232 model (points and condenser). It had been sitting in storage for about 10 years. I cleaned it up, filled with fresh oil, fuel & started engine. It ran for about 10 seconds & stopped. I checked the coil & the spark had become vey weak.
I purchased a second hand coil and fitted it to the unit and it started - this time it ran for about 5 minutes and the same thing happened again - spark had become so weak that it would not fire.
Any ideas on what could cause coils to fail prematurely or is this a common thing??
R. King
10-28-2004 07:12:26
 Re: Blowing coils on Briggs 5hp in reply to Preston, 10-23-2004 21:12:14
Sounds to me that the condenser is breaking down causing excess heat in the windings. Replace the points and condenser and you should be O.K.
ronnie269
12-03-2005 19:33:05
 Re: Blowing coils on Briggs 5hp in reply to R. King, 10-28-2004 07:12:26
anytime you replace the coil always repace the condensor too!
wasp
05-16-2005 20:26:13
replace the armature with a magnetron conversion
no more pts or problems
