Stationary Engines Discussion Forum
Coil ,or mmaybe a new owner for 23 series Briggs
Gene Davis (Ga.
11-18-2004 19:53:34
Any body got a coil for a 23 series Briggs magneto they want to part with reasonable? Or maybe how about the brackets and pulley for a starter/ generator? If I can find these I can convert it to battery ignition. This engine is almost unused. Foresty Dept surplus was run very little because of hard starting since new in '65. They took it off, set it aside and sealed it up. I took the aircleaner off and got the aircleaner wing nut out from under the choke butterfly and it starts good now. It has the military sealed style ignition on it now. The coil begins to breakdown after about a minute or so of running it begins to miss some, has a weak red spark, then quits firing completely. Guess the best thing would be to civilianize it now. It runs very smoothly with a battery ignition coil. I have no need for this engine and would like to find a sale for it as soon as I get an ignition system on it unless some one wants it like it is and they put in a coil,or battery ignition on it. If any one is interested in it, e-mail me; gadavis@direcway.com and we can discuss it. It is set up with a fuel pump and hook up for using either the engine tank, or an extended run remote tank system. It is almost unused, and has so much compression you have to pull rope with both hands. Gene davis
Kent of SW MO
11-19-2004 07:01:28
 Re: Coil ,or mmaybe a new owner for 23 series Bri in reply to Gene Davis (Ga.), 11-18-2004 19:53:34
Gene,
I modify later B&S magneto coils to replace the 290880 coil. Also mfgsupply.com has new ones for $30 but they may be Chinese made. If you will unblock you E-mail I can send you the coil mod. instructions and some picture. I have used this modification on Models 9,14,and several 23. I have not yet modified my Model 19 yet.
Kent
TimV
11-19-2004 12:57:19
 Re: Coil ,or mmaybe a new owner for 23 series Bri in reply to Kent of SW MO, 11-19-2004 07:01:28
The MFGsupply coil is indeed China-made. However, I bought one for the M19 on my Wards (Simplicty) model W walk-behind tractor, and so far it's worked fine. $30 is a whole lot easier on the pocketbook than $95 from my friendly local Briggs dealer! Besides, it wouldn't suprise me at all to find out the Briggs OE one was also China-made.
Bill Klein
11-18-2004 20:19:09
Drop me a line at work by sending to parts@sandylakeimp.com. I am sure we have st/gen brackets & may have a good used coil. Bill Klein, Sandy lake Implement
