Stationary Engines Discussion Forum
Help identify 4 cyl air cooled the size of IH Cub
Newman Red
12-27-2004 08:57:19
I bought an old buzz saw with an inline 4 cyl air cooled power plant. It has a fan shroud that looks somewhat like a twin Wisconson, a distributor, a Marvel Shelber updraft carb, and conventional autolite starter. It has a typical power plant hood with front and rear panels. It also has a typical lever operated clutch. This is an overhead valve engine with flat plates on top of the head for valve covers. Exhaust manifold is a "log" with pipe plugs each end and center on top.
Newman Red
12-28-2004 17:39:07
 Re: Help identify 4 cyl air cooled the size of IH in reply to Newman Red, 12-27-2004 08:57:19
Thanks Jim. Actually this engine is a little bigger than a Cub but not as big as a Farmall "A". Any idea where I might get pictures of the Wisconson to compare to my engine?
Bob
12-28-2004 19:36:27
 Re: Help identify 4 cyl air cooled the size of IH in reply to Newman Red, 12-28-2004 17:39:07
Case made a 4 cylinder air-cooled, too.
Link
Newman Red
12-29-2004 16:07:56
 Re: Help identify 4 cyl air cooled the size of IH in reply to Bob, 12-28-2004 19:36:27
The engine pictured is like mine. Mine however is set up as an agricultural powerplant with hood, in out box, conventional air cleaner etc. Thanks for your help. Dennis
Jim s.e. ohio
12-27-2004 10:52:25
AC 4 Wisconsin ? 16hp at 2600 rpm 1934-1945
