Stationary Engines Discussion Forum
Kohler engin no spark
vinnie
01-01-2005 11:55:14
10 hp kohler when I try to start it you have to turn it over very fast or there is no spark at all,points look good , have tryed different condensers still only sparks when it is turned fast What can be wrong with it? Thank You for any help Vince
ronnie269
12-03-2005 19:22:59
 Re: Kohler engin no spark in reply to vinnie, 01-01-2005 11:55:14
clean your fly-wheel real good (magnets) IF you have electronis egnition it has to turn 600 rps but with points ans condenson it makes no difference
Kent of SW MO
01-03-2005 06:31:49
If this is a magneto ignition, it may be a bad coil. If the engine is old enough the coil is no longer available from Kohler. I had this problem on a K-161. I was able to make a coil from a Tecumseh work on the K-161.
Kent
vinnie
01-01-2005 18:27:50
Bob it is a magneto ignition model K241T
Bob
01-01-2005 14:20:49
Battery ignition, magneto ignition, or electronic ignition?
Probably a K-241?
Also, you can view or download a manual with troubleshooting information on all the ignition systems for free at:
Bob
01-01-2005 14:20:05
Probably a K-241?
